Hi Tom
i try to avoid the pc lag, i use the same pc to control 2 machines (one with kflop and the other with mach3 by paralel port), by this way i can use two machines at the same time
anyway, how can i modify the feed rate override with the MPG? my pc and the machine are not near
another request, when i work with 4 axis in the Gcode viewer the 4 axis (A axis) is unrepresented, when i have to mill 2 face (rotated 90º) all the trayectory line of both milling remains overlapping, it´s imposible to know that happen with the milling
thanks a lot
Adolfo
